Teba TFB 46-51Y
  • #11602
    ddas
    Hi Folks
    Wonder if anyone can help.
    I need to get hold of a thermostat for the above electric oven but understand that Teba have gone into receivership. The stat in question is an overheat stat (I think) and is situated on the back of the oven on the right hand side (looking at it from the back). I have done a search on-line for a replacement stat without any luck. A further problem is that I don’t know what temperature this stat operates at as there’s nothing on the stat that indicates what it might be. Does anyone know where I might be able to get a replacement stat or what max temp this oven is supposed to get to before cut out?
    Thanks in advance
    #145961
    Re: Teba TFB 46-51Y
    hi
    give me a call on tuesday on 07961 365484 and i’ll sort one out for you.
    bryan
    #145962
    ddas
    Re: Teba TFB 46-51Y
    r600a wrote:hi
    bryan
    cheers mate
    #145963
    Mibol_Zaritchy
    Re: Teba TFB 46-51Y
    dont know if its any help but i am about to scrap a teba TFA 10-31Y oven and hob, maybe the element you require is the same part in this unit ? if so, its yours free.
