Tech info requested for Bosch tumble dryer WTB84200GB/09
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tech info requested for Bosch tumble dryer WTB84200GB/09
  • #100146
    twicknix
    Customer saying that the machine is saying water tank full and machine not finishing the cycle on Cottons cupboard dry plus program.
    it is heating up fine and water tank appears to be working.
    not the easiest machine to work on due to the way it was constructed.
    I would like test the sensor and check the state of condenser water pump.
    I am hoping that the tech info will help me to identify and test to properly diagnose the fault.
    thank you in advance
    #479447
    with that fault i would check and clean pump umit
    the full sensor is 2 metal contacts that touch the water as it rises. if its contaminated or there is lint in there this fault will occur
    twicknix
    How do I get to it? It looks like that I need to remove all the skins off to access the pump? In some respect AEG and Hotpoint tumble dryers are best for working on due to accessibility.
    #479449
    they are no where near as bad as you think
    remove top
    remove front panel
    remove screws holding right side and remember the one underneath
    the panel needs to be teased around the water container to then remove it
    takes less than 10 mins and all you need is 2 drivers torx 20 for the screws into metal and torx15 for the plastic ones
    job start to finish should take no more than 30 min
