Re: Technical advice from manufacturers?
kenlawred wrote:Does this happen in the domestic refrigeration area?
Not unless you do contractual work for a manufacturer would you necessarily get technical info. However some manufacturers like Electrolux for example are more open toward the independent trade and a good deal of technical info on their products is freely available. Beyond that there is a wealth of knowledge within the forums here on UKW to help you out should the need arise.:wink:
HTH? 😀
