Re: Tecnick DW2677/1 (whirlpool) wireing loom damaged.
should be 480140100687
listed as protect wiring but check on it have no breakdown but if you do a google search did find a site with a picture
wire
somtimes if the wire will move there is enough slack to pull wire up or down and joint it. if not find a new peice of suitable wire from a scrap appliance (not stripped flex) and joint top and bottom. also where there is 1 wire gone the rest will be going check for cracks in the insulation and repair if necessary. As an added precaution if possible move the harness about 1 inch higher or lower so it bends in a different place
hope this helps
