Tecnik 2677 Runs and Runs and Runs……
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Tecnik 2677 Runs and Runs and Runs……
  • #35479
    Doobrey
    Hi guys,
    I have a Tecnik 2677 Dishwasher, which is approximately 4.5 years old. About 6 months ago I had the pump replaced, which seemed to make the machine work wonderfully.
    Anyway, From yesterday, the machine starts it’s cycle and just runs and runs and runs – my girlfriend noticed it was still running after about 5 hours!
    The only thing we can think that we have changed is that i filled up the salt and rinse aid the other day – since then it hasn’t worked properly. If we put it on a rinse cycle, it goes through the 30 mins cycle and stops.
    Any help please!
    Doobs.
    #246727
    Doobrey
    Re: Tecnik 2677 Runs and Runs and Runs……
    It also doesn’t seem to be getting hot in there…Is this broken and need a brand shiney new one?
    #246728
    Hi Doobrey,
    Sounds like either a heater or thermostat problem, both will be located underneath and neither being faulty should scrap the machine. Power off if you go in to have a look.
    Doobrey
    Thanks – I’m new to this – how would I determine if either 1 is faulty?
    Doobs.
    #246730
    Just meter them and see if they’re okay.
    Doobrey
    Ok – im an newbie – how do I meter?
    Doobs….
    #246732
    And at that stage Doobrey I’d suggest you get a professional in. You need to be able to meter the components out to check them for continuity to determine which one/s are faulty.
