Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › TECNIK 795 / NO POWER PROBLEM
- This topic has 8 replies, 5 voices, and was last updated 19 years, 6 months ago by
beebee.
October 3, 2006 at 12:43 pm #21360
beebee
Participant🙁 Tecnik795…have power getting to the main on / off switch and leaving that for the main processor control board…but no power showing on the door indicator lights and the machine is totally dead…any suggestions very welcome…thank you.
October 5, 2006 at 3:18 pm #190589linrew
ParticipantRe: TECNIK 795 / NO POWER PROBLEM
hi
it sound like a module problem, there are many versions ranging from £64 to £83 plus vat
can we have the full number from the machine
the number should be stamped on the stainless steel at the top of the door just buy the door lock (very difficult to see)
is this a tecknic TKD795/2 or TDK795/3
it may be marked SE6TIE1GB/?? or SE6TIE2GB/?? instead of the tecknik numbers
linrew
October 5, 2006 at 3:40 pm #190590beebee
ParticipantThe machine appears to have no serial ID stamped on the stainless steel. The book just refers to it as a TKD 795 and it was bought in 1999. The main circuit board is a JABIL 084561…any help???
October 6, 2006 at 1:59 pm #190591linrew
hi
sorry but i cant find anything remotly near jabil 084561
without the full model number i cant help (sorry)
there appears to be many diffrent versions of the TKD795
i would suggest trying tecknik direct and see if they can help
the only number i have is 0161 7864692. ask for technical helpline
linrew
October 24, 2006 at 12:29 pm #190592AmberDog
Hi, my machine has the exact same problem and started at the weekend. It has a label on the front door with both numbers on it – TKD 795/2 & SE6TIE1GB V.
I have tested the switch and power is going through it to the control module but also does not have any lights on it.
Any help with what parts i need to get it working again greatfully received as i don’t know how much more washing up i an take 😳 !October 24, 2006 at 12:34 pm #190593beebee
ParticipantAll my investigations pointed to the main control module. You can buy these and easily install them but wait for it…they cost about £105! Since my machine is 5 years old I’ve decided it’s just not worth it and will probably buy a new one…
October 26, 2006 at 3:41 pm #190594linrew
hi
the part number for the module for you machine (SE6TIE1GB/13) is 264482.
the cost is 83 quid plus vat and delivery from bosch(bshappliancecare.com)
linrew
October 26, 2006 at 11:27 pm #190595Penguin45
Funnily enough, that comes to £105…………
October 26, 2006 at 11:57 pm #190596kwatt
KeymasterI thought the TKD795 was a Whirlpool in disguise. From memory they changed to BSH in 2002.
