Tecnik Dishwasher SE6TIE1GB/12
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tecnik Dishwasher SE6TIE1GB/12
  • #31907
    bassman
    I looked at this machine for a friend it fills and heats water the circulating pump runs ,it heats up to temperature then after about half an hour the machine cuts out, the mains and program light goes out and the machine will not switch back on again, after a few hours the machine will run again it is a Bosch machine and I think it may be circulating pump overheating and cutting out on overload but as it is a built in machine and I am not too well these days I am hoping some will have come across this before and and may have a sugestion of what to look for or a wiring diagram to see if motor overload cuts out the complete machine.
    #232873
    gegsy
    Re: Tecnik Dishwasher SE6TIE1GB/12
    I would have a look at the mains socket and plugtop for signs of overheating. Have seen this a few times.
    Wouldn’t do ant harm to look for dry joints on PCB 😉
    nomadPaul
    As Greg says , check the mains socket . It could be a scenario where the plug has ‘sunk’ into the rear ‘tarmac’ of the appliance and could be being pulled out slightly as the machine heats up and expands . Also , if its been hard-wired , you can have probs with loose electrical connections in the socket where , again , as it heats up due to the power draw of the heater , the connections can become dis-connected which then re-connects as the wires cool down .
    Personally , i’ve not heard of a motor cut-out affecting the whole board .
    #232875
    bassman
    Thanks for the replies I,ll check the mains first and post again when I,ve had a look at it
