Tecnik Dual Fuel Range Cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tecnik Dual Fuel Range Cooker
  • #75702
    garn
    Hi Chaps
    Iv Failed to remove the main oven rear panel for the removal of the element and fan.
    Removed the 4screws and ended up removing the Bottom & top elements.
    Sorry Theres No Model ID Plate on This
    This back plate is stuck solid
    Am I Missing Something Hear I dont Want To force The thing.
    Thanks Paul…
    #395897
    Re: Tecnik Dual Fuel Range Cooker
    are you sure it does not load from the back like the candy F series
    garn
    Never Done A candy F series.
    The Screws for the fan are behind that cover. The main oven element screws are located behind the rear panel
    Which i removed.
    The rear cover That The fan is mounted on is riveted on.
    The Customer Had a Gloss Mag With And illustration Examle It Said E-nr And Fd Code So I asume This Is A Bosch Branded As Tecnik.
    #395899
    with a lot of this style of cooker the model is inside lower flap below the oven door ( bottom of picture 1 ) did you look there
    garn
    Yep Had the bottom off the thing in pieses the only thing i havent done is pull the insalation of the back of the oven for inspection.
    oven elements are avable in ukwg shop and the internet so there must be away of removeing the element .
    im. going to call back this afternoon with the customer.
    Thanks Dave il let you know the update.
    paul( scratching is head )
    #395901
    Hollytree_Technical
    I have just had the pleasure of seeing one of these this morning for a different fault (small oven grill element) but I took a look while I was there and the procedure appears to be this:
    1.Remove the six screws that hold the outer back cover on the appliance and then remove the cover.
    2. Disconnect any wires etc so that you can remove the big pad of insulation to fully expose the inner silver panel (with fan and element mounted on it).
    3. Remove the four screws inside the oven that hold the inner silver back panel on.
    4. The silver panel appears to be stuck in position using some form of sealant so it will need carefully prising off.
    5. Remove old element.
    6. IMPORTANT – the screws that hold the element are NOT self tappers so run a tap through the holes in the new element (Guess who has just found out the hard way 😳 )
    7. Reassemble in reverse order and test.
    Hope that helps
    Jem
    P.S. The model number that I was given if it helps is TKC1285
    #395902
    garn
    Thanks mate I really Appreciate The Help The model No is Smack On With You Just been Over And Had This Time It Where Dave Told it Was.
    Model TKC 1285 Sn 0032k02985.
    Thanks Again Dave And Jem
    Paul..;.
