I have the above integral dishwasher and over the past week it has began to beep continuosly near the end of the cycle. When I open the door the start light flashes four time, can anyone tell me what this error code means?
IIRC you need to check that the machine has drained correctly…if not then you need to check the filters and the drain line (sometimes they block at the sink waste connection.
If that doesn’t solve it then its probably engineer time.
Have a look at Repairs@ for an engineer local to you?
