Tecnik DW2677/1
  • #34609
    mkmscannell
    original circulation pump Askoll packed in which im told is common enough but i replaced it with a recommended alternative from whirlpool and it was fine for 4 days but its now packed in with the start light flashing.
    any ideas before i crack up
    #243314
    kelland
    Re: Tecnik DW2677/1
    when you had the machine out to repair did you push it back and possibly squash up the fill hose so its now not taking water?
    #243315
    mkmscannell
    Re: Tecnik DW2677/1
    No hoses are fine both in and out, i poured water into the pump from the inside of the dw but it didnt throw any out. Last time the original pump failed however i didnt get any flashing or alarms? do you reckon something else is at fault?
    #243316
    Re: Tecnik DW2677/1
    Count the flashes……….
    mkmscannell
    Re: Tecnik DW2677/1
    4 flashes then pause. (drain problem according to book) still not convinced its actually filling but defo water as far as unit
