Tecnik Fridge freezer failure.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Tecnik Fridge freezer failure.
  • #71266
    rsjon
    Our Tecnik fridge freezer (Model TKR 6245-LH #781304300050303) is failing to cool.
    The compressor is not running but the internal fan is when the thermostat is set cold. This leads me to believe the thermostat is operating correctly.
    I have measured the resistance between the three pins on the compressor and they are approx: 10 Ohms, 12 ohms and 22 ohms which I think sounds about right (two of the windings add up to the value of the third reading).
    I have replaced the compressor starter/relay module to no avail.
    I have checked the wiring/connections to the best of my ability (no cct diagram) and not found anything amiss.
    The fridge is about 8 years old and I believe it is basically a Whirlpool model.
    I suspect either the compressor is dead anyway or the gas has leaked out. If anyone has any other ideas please help as I don’t really want to buy a new one unless I have to! 🙁
    Thanks in advance,
    Jon.
    #380536
    Re: Tecnik Fridge freezer failure.
    Gas won’t leak unless there’s a reason.
    The compressor could be gone though.
    rsjon
    No known reason for a leak.
    How do you know if the compressor is kaputt?
    Jon.
    #380538
    Experience. 😉
    If the compressor is running and the thermostat operating as it should then the likelihood is that the compressor seals have failed to a degree allowing the refrigerant to bleed into the compressor oil. The compressor is essentially just a simple motor or pump to compress the refrigerant gas suspended in oil on springs inside a sealed casing.
    If it can’t compress the gas, no refrigeration.
    rsjon
    Understood, but this compressor isn’t running at all!
    Jon.
    #380540
    Probably kaput then if the stat is okay.
    Dales-Electronic
    Have you got mains power at the compressor relay and overload assembly – when switched on do you hear a click after afew seconds?
