tecnik oven door not closing tight
Home Forums Public Support Forums Help And Support Cooker And Oven Forum tecnik oven door not closing tight
  • #65043
    jsmith1
    I have a Tecnik electric double oven. The top oven door shuts firmly with what appears to be a cam action built into the hinges. However the lower (larger) oven door does not shut firmly and leaves a slight gap at the closure end of the door. Are these hinges adjustable? or do they have to be replaced. In either case how is it done?
    #358992
    Re: tecnik oven door not closing tight
    We’d need a model number to help you.
    But normally, the hinges won’t be adjustable and will probably need replaced.
    HTH
    steve1
    HI
    YOU WILL NEED 2 HINGES AND 2 HINGE RECIEVERS
    #358994
    wsts
    If it’s a later stoves build only the hinge itself would be required.
