TECNIK SE6TIE1GB/17 Dishwasher ‘pumps’ when switched on
Home Forums Public Support Forums Help And Support Dishwasher Help Forum TECNIK SE6TIE1GB/17 Dishwasher ‘pumps’ when switched on
  • #45388
    richy_pv
    I have the above model integrated dishwasher.
    It has an intermittent fault where as soon as its switched on, even with the door open, it begins pumping.
    When left for a couple of weeks it seems to rectify itself – the fault soon returns after a couple of cycles.
    Can anyone shed any light on the problem and a possible fix?
    An idiot friendly version would be ideal as my knowledge of dishwashers starts and ends with loading and unloading.
    #285523
    Re: TECNIK SE6TIE1GB/17 Dishwasher ‘pumps’ when switched on
    Flood protection operated – water in the base moulding will operate a float switch, which in turn runs the drain pump.
    Pull the plug, drag it out, remove side panels and tip the machine over to drain the base. Try then running a programme and see if you can observe the leak.
