Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Tecnik TKC1285 poor heating
- This topic has 4 replies, 3 voices, and was last updated 12 years, 3 months ago by
scortedvan.
January 7, 2014 at 12:06 pm #78901
scortedvan
ParticipantHi All,
First post here so thank you in advance for any help that can be offered! I have just moved into a new house and there is the above cooker fitted which certainly looks the part but……..
when the static oven option, or the conventional fan oven settings are selected on the main (left) oven the heat really doesn’t get very intense. The red led illuminates and once a temperature has been selected with the next dial the orange led underneath illuminates to indicate that the thermostat is sensing temp, but this should go out once the requested temp is reached and from then on cycle as the temp is maintained. If i input max temp, and leave the cooker for 30 mins, the stat light will still be on and although the inside of the oven is quite hot its not 230 degrees hot. In fact if i turn the temp dial down slowly to see at what point the stat light goes off its around 110 degrees. Surely this isnt normal?
This is much the same for the smaller oven (right) but with the same test i can barely achieve 80 degrees.
One other thing i notice is the control panel fan kicks in with in 5 minutes of the oven being switched on, and has done every time ive tried it, again this may be normal but seems unlikely. Does anyone have any suggestions or similar faults that they have come across? and does any one have a a wiring diagram or repair manual for this oven?
Wow thats a lot of typing haha
Thanks again,
Joe
January 7, 2014 at 4:12 pm #407319Martin
ParticipantRe: Tecnik TKC1285 poor heating
Your will have to contact BSH Appliance Care for info on this obscure brand.
January 7, 2014 at 7:52 pm #407320scortedvan
Yeah it seems a little obscure, some sort of ‘moden buy our kitchen and get this big shiny thing free’ by the seems of it. There’s also a tecnik fitted dishwasher which appears to be u/s aswell!
Done a little work this evening, and the seals are all poor on both doors which clearly won’t help anything. And just looking now at the main oven (left) when set to fan assist and max temp, both upper and lower elements heat up rapidly when checked with a pyrometer but the rear fan element much much slower and this may be just down to radiation from the other two. Which may explain things? Yet to remove and check resistances but…….
In optimism of a failed fan element would anyone know where to source one along with a fl set of door seals?
Thanks again
Joe
January 7, 2014 at 8:08 pm #407321Martin
You need to contact BSH Appliance Care for spares.
March 19, 2018 at 1:22 pm #407322l.haigh
Hi. I don’t know if you will see this but I have just moved into a house with this oven and exactly the same probs. Did you find an answer? Thanks Luke
