Tecnik tkd 795/2 dishwasher – cannot remove waste hose
Home Forums Public Support Forums General Enquiries And Questions Tecnik tkd 795/2 dishwasher – cannot remove waste hose
  • #85500
    P Hildick-Smith
    Hi I would be grateful for some advice. My tecnik dishwasher has stopped working. I have found that the waste hose has a hole in it (mice I wonder?). I have removed the dishwasher from the kitchen unit. The waste hose disappears into the bottom left corner at the back of the machine. How can the waste hose be removed? Pippa
    #428739
    jess1ca
    Re: Tecnik tkd 795/2 dishwasher – cannot remove waste hose
    Hi Pippa
    Yeah Lean the dishwasher so access bottom panel which usually is held with 4 self tappers then you will see the drain hose on pump it will be a elbow end on pump end so when you purchase a replacement hose make sure the sizes are correct The only drag is pulling the unit from kitchen unit ….
    #428740
    P Hildick-Smith
    Thanks very much I will try that.
    #428741
    P Hildick-Smith
    Took machine out from under unit. Tipped it onto its back but there are no screws to remove the base. Also looked at the bottom of the front panel but nothing to undo there either. I have now used duck tape to completely seal the hole in the hose and machine is working again. I will have to see how long the duck tape holds! Thanks for your advice. Pippa
