Tecnik TKD 795/4 dishwasher Drain pump
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Tecnik TKD 795/4 dishwasher Drain pump
  • #61030
    bandit2510
    Can anyone give me a part number for drain pump for this model, I believe it is Bosch made appliance.
    #344637
    Re: Tecnik TKD 795/4 dishwasher Drain pump
    If it is the Bosch then you need 423048 (TKD795/3).
    Mpt do a pattn for £11.
    If it’s a Whirlpool, then any old three screw job should fit; though check for toc.
    Mike.
    #344638
    bandit2510
    Thanks Mike ….It turns out its a Siemens made machine cant find model or part on mtp or connect any more ideas?
    #344639
    Siemens, Bosch, they’re all the same aren’t they? Only slight doubt I have is that the part I gave you there is for 795/3 but it’s probs just the same. Have you seen the old pump? Does it look different from the one I gave you above?
    Alternatively, I’d think the thing should have a proper Siemens e-nr on it somewhere. Espares.co.uk will show you (or the customer) where to look for that with specific instructions for Tecnik. With that you can search the Siemens e-shop which is like the Bosch one.
    Mike.
    #344640
    loaf
    Nice patterns available for those 423048, use BS51117 from Masterpart.
