Tecnik TKD795
  • #36126
    zoot_horn_rollo
    Hello, first time caller here…
    My Tecnik dishwasher won’t stop trying to drain when I open the front. I have tried resetting by pushing the appropriate buttons as per the user manual but this doesn’t have any effect.
    I have switched off at the mains but when Is witch the power on it keeps continuining to drain and then I get a inlet water fault showing on the panel.
    Any ideas?
    #249660
    Re: Tecnik TKD795
    Base underneath will be flooded, flood protection activated so drain pump running and over-riding any programming. Drain the base, if it does it again it’s “Hunt the Leak” time.
    Power off first.
    zoot_horn_rollo
    Re: Tecnik TKD795
    Thanks for that tip, which I will try later today.
    Would the programme overriding include continue to try to drain when the front door is opened and when it normally cuts out?
    #249662
    Re: Tecnik TKD795
    Yup.
    zoot_horn_rollo
    Re: Tecnik TKD795
    Ok, leaving the door open for a while seems to clear the problem and it switches itself off. However, on restarting the programme the low water error light comes on and after a while the pump restarts and goes on for a while again.
    Is this indicative of a water leak in the base?
