hi is this machine a badged unit or are tecnik a brand ?
reason i ask is my sons intergrated washer tecnik tkl9060 has a door seal that needs replacing (worn extremly thin and will soon leak) seams an easy fix if the part is available.
carnt seem to find parts anywhere :rolls:
Hi thanks for the rapid responce 😀 the machine is built in will endeaver to remove it and relay the details from the plate to you in the near future.
