Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Tecnik tkl9260 – Help – went ‘bang’ the other day!
- This topic has 12 replies, 3 voices, and was last updated 19 years, 1 month ago by
essexgal.
March 22, 2007 at 4:33 pm #26064
essexgal
ParticipantHi, I have just found this forum and wondered whether anyone had any idea/advice on how big the problem might be? ❓
Last weekend my daughter was ill resulting in the washer going overtime and on the final load – a sleeping bag – it got to the spin stage and sounded as ther was a ‘clicking’ sound as it spun, then a small ‘bang’ and the power was tripped and there was a small puff of smoke coming from ? top of machine. Thought that the sleeping bag had been too much/too heavy reset power and later tried machine again. Fills OK and drum rotates but as soon as speed picks up then goes ‘bang’ and trips power again.
Does anyone have any ideas on what the problem could be? Machine is just over 4 years old and has been very well behaved up till now 🙁
Thankyou.March 22, 2007 at 7:57 pm #208621Penguin45
ParticipantRe: Tecnik tkl9260 – Help – went ‘bang’ the other day!
Does the clicking noise vary with drum speed?
March 22, 2007 at 8:37 pm #208622essexgal
Yes – it seems to be related to the speed – goes at the same rate as the drum I think – have only tried to run it once more since the original prob though.
March 22, 2007 at 9:08 pm #208623Penguin45
If it’s one click per revolution, I would look very carefully at the state of the inner drum – it is possible that you have a split seam. The click may be the broken part hitting the heating element under the drum. If the element is actually damaged, it can blow the fuse.
Penguin45.March 22, 2007 at 10:45 pm #208624essexgal
ParticipantI’ve just had a good look at the drum and can’t see any splits or broken areas. I spun the drum and the sound is similar to when you move the pedals on a bike backwards – the sound is different and a higher pitch than previously pre-sleeping bag. Don’t think I’m doing a very good job here with describing it!!!!!!
Would it help if I tried to run it again tomorrrow so I could describe it better?
ThanksMarch 22, 2007 at 11:04 pm #208625iadom
ModeratorRe: Tecnik tkl9260 – Help – went ‘bang’ the other day!
It sounds as though a section of the commutator in the motor has lifted. It would suggest new motor time. 😥 I wouldn’t keep trying it, you may blow more than your circuit breakers if you do.
March 23, 2007 at 12:18 am #208626essexgal
ParticipantThat’s what I was thinking it might be 🙁 Have you any idea what the cost of replacing a motor might be or even if it is worth doing??
The machine was bought just before we moved here by the previous owners so we inherited it but if we replace it we’d neeed to get another integrates one – do you know where/how I can go about finding out more about what would be the best/most reliable replacement? Have looked for reviews but not come up with much but probably looking in the wrong place?
ThanksMarch 23, 2007 at 9:31 am #208627iadom
Not well up on Tecnik, they can be made by several different manufacturers. The Bosch/Neff range is a good standard to aim for with integrated appliances.
March 23, 2007 at 9:37 am #208628essexgal
ParticipantThanks Jim – just one more quick question! Is it, in your opinion, worth the initial outlay for something like a Miele machine – I know they are very expensive and the thought of over £1000 for a washing machine is quite scary but is anything built to last nowadays?
Thanks, Jane 🙂March 23, 2007 at 10:39 am #208629iadom
Now you are talking, seriously good machines, will last 15 to 20 years with luck. most of the higher priced Miele come with 10 year conditional warranty as well.
Over 25 years ago a decent machine would have cost £250 to £300, almost your £1000 in todays money. Lots of 20 year old machines still working perfectly well, unfortunately the same cannot be said of todays £200/£250 machine.
Jim
March 23, 2007 at 10:41 am #208630essexgal
ParticipantBetter start saving up then!!!!!!
Thanks for your advice – I appreciate it 🙂March 23, 2007 at 8:29 pm #208631Penguin45
Machine is manufactured by Siltal. The drive motor is p/no 49558700 and should be around the £100 mark. An email with the part number to spares@ukwhitegoods.co.uk for confirmed prices and ordering if you wish to proceed with a repair.
Penguin45.March 24, 2007 at 12:05 am #208632essexgal
ParticipantThats really helpful, Thanks 🙂
