Tecnik Washer/Dryer TKL9909
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Tecnik Washer/Dryer TKL9909
  • #90401
    victoria97
    Does anyone know how to work this machine – even with the manual it is not easy to set up a washing cycle that works. It is so frustrating. For instance, If I wanted to do a 40 degree wash only what do I do? It seems to do the wash and does not rinse. Does the rinse have to be done separately? I just cannot work it out.
    #444667
    1totalshambles
    Re: Tecnik Washer/Dryer TKL9909
    Information on the net is really sparse as are any spares listed.
    A guess! If you know the start of a wash programme is correct and the machine gives up and does nothing after pumping out the wash water, so you are now on the 1st rinse, one part of the inlet valves looks like it has failed OR to confuse things more if this is a hot and cold fill machine? it might be filling with hot water only where it should be filling with both and the cold is tap is turned off so no fill at rinse stage.
    Sorry I thought I`d have a crack at this since noone else has but that`s probably because they, like me, can`t find any or little info on this machine.
    If you can post a picture of the programmer knob and any decals that surround it and where you are setting the programme I might come up with a suggestion.
