Anyone know the part number for the fill hose on this machine. It’s got a normal twin solenoid fill valve inside but an aquastop in the hose which has failed. Any idea’s 😕
Got same fault on this machine. Aqua stop failed and machine wanting water. The aqua stop was buzzing all through the wash so I’m presuming a triac on the pcb is at fault. I’m guessing that the machine will operate as normal with a standard fill hose and that the aqua stop is just z safety device? Is that right?
No power to aquastop this time, same symptoms but aquastop ok. Worked fine for three weeks but try explaining that one. Is the pcb still available…may try using a standard hose to see if it causes any more problems if it isn’t. Anyone tried that…does it work?
