Pumps out,then fills and pumps out at the same time,stops and fills and then pumps out again and stops with first three lights flashing. Thought it looks Smeggy ,checked fault codes- apparently it detects a faulty flow meter(which it doesn’t possess??) -but it just needs resetting.Read the reset instructions:’Power off.Switch on and within 3 seconds press start 4 times.Switch off ,wait,switch on and run rinse program.’However there’s only 2 buttons on the top,an on/off switch and a program selector switch. I tried the above reset procedure using the prog selector as start button but no joy.Am I missing something?
