Teka DW 59 FI fault
Viewing 1 post (of 1 total)
  • #40519
    sritchie
    Hoping that someone can help with an error on the stated model.
    Initial problem was that the Salt light came on and the dishwasher had become non-operational with some water still residing in the bottom of the machine.
    We tried to manually get rid of some of the water and topped up the salt level.
    The Salt warning light is now off but the dishwasher is still not working.
    Here’s the issue now:
    At switch-on, the two right-most lights on the display (of 5 lights on the PCB) are flashing. (Error isn’t detailed in manual).
    When a program is selected and started, the machine will go through the motions for a few minutes before stopping.
    After opening the door, the three left-most lights flash with the single right-most light fixed. I’ve seen this referred to as E7 but this is not detailed in our manual either.
    I’ve tried a PCB reset (pressing program button 4 times quickly at turn on if this is correct?!) but this doesn’t appear to do anything.
    Turning off and back on then takes us back to the start with two right-most flashing lights.
    Any ideas?
