Teka DW6 45FI malfunction
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Teka DW6 45FI malfunction
  • #92110
    SuziB
    Hello, my Teka DW6 45FI dishwasher has started to play up this week – the programme starts ok, but seems to get stuck in a loop on the wash phase (for hours!) with a “beep beep” sound coming every so often before it goes into wash again (this happens on all wash cycle options) – any thoughts on correcting this would be great! (I’ve refilled the salt and cleaned the filter….) – thanks in advance!
    #450302
    Simon46
    Re: Teka DW6 45FI malfunction
    Capacitors have died on the smeg pcb.
    #450303
    SuziB
    Ah thanks Simon, do you know if this is usually an expensive repair as the dishwasher is 6+ years old…?
    #450304
    if its just the cap failure and you find an engineer who will do it
    no it should not be expensive as the component required is cheap
    SuziB
    Thanks Dave – will get someone out 🙂
