Re: Teka intergrated dishwasher
you need to do the reset procedure:
(am doing this from memory, have posted this many times if you want to search)
with door open, switch on the power switch and within 5 seconds (ie before any of the leds light up), push the program button 4 times. You should now have a light on (or flashing) at either end, if not then switch off and try again until you do.
Once you have the 2 lights on, then press the programme button once more and one of the lights should go out, you should now have only the one light on.
switch off the machine to save setting.
Should then be back to normal, if not try it once more.
