Teka ls1000i stalls mid way
  • #48806
    Johnnyboy
    Hi Guys , this nTeka washes until half way ( rinse bit ) through then stops , zero, zilch nada,(drum empty) but press extra rinse button off it goes until number 5 ( spin )then zip again. These parts are V expensive and non returnable any help please. Motor during wash rotates L & R and it heats water reaches all compartments and the valves all work.
    Cheers Johnnyboy
    #297791
    Re: Teka ls1000i stalls mid way
    Where are you going to buy spares from? This is just a Candy in a dress as far as I can tell.
    Sounds like a timer fault to me.
    Johnnyboy
    The type is not the new candy digital but push button and mechanical.
    spares from Connections
    timer part no TEK40821151 £250,TEK40821479 module £118 just worried Im getting it right.
    #297793
    Try 92208156 for the timer from a wholesaler who won’t rip you off.
    Module is 91964239, but I’m pretty sure that’s just a motor board.
    funkyboogy
    we just recently ordered very expensive teka spares via connect , just like part no you have . you dont get any pictures of parts so identification inpossible… and yes they were wrong.. £300 + , got them sent back ok ..
    can you let me know if the candy spares are correct
    cheers ally
