Teka oven fault codes?
  • #41715
    Ray9500
    ….does anyone know what E04 means on a built in Teka oven?
    just needed a heads up before heading out to the beastie 😀
    Many thanks
    Ray
    #271110
    DentedPorsche
    Re: Teka oven fault codes?
    Hiya,
    If you’ve got the model number I’ll see what’s on their website.
    Brian 😀
    #271111
    Ray9500
    Many thanks Brian, its a HM835.
    I have had a look at it and found the lower element open circuit, hopefully this is what the fault code refers too ❓
    Regards
    Ray
    #271112
    Ray9500
    bugger…..oven heats up nicely now but i still get the E04 fault code after about 20 minutes 🙁
    any help/ideas appreciated 😀
    regards
    Ray
    #271113
    DentedPorsche
    Hiya,
    It’s too long winded to type out.
    Download it here
    http://rapidshare.com/files/175247321/hm835.pdf.html
    Hope it helps.
    Brian
    #271114
    Ray9500
    Excellent stuff Brian 😀
    Its so obvious with the right info!
    Thanks again
    Ray
