For the database this one activates float switch on empty by filling base with water. Breather hose on drain vessel found dislodged by top concrete weight rubbing against it at top rear right of machine. I expect chafe to follow in time?
Finally the breather hose has chafed through on this Bosch WXLITI01GB/18 and the concrete top weight has hit the inlet valve cracking it. I see there are three holes for the tub springs. Should the drum be moved forward to stop this problem happening again?
Replaced hose again from back of drum to the reservoir that is in line with the drain pump and waste hose on this bosch machine. What would happen if the hose was removed and the holes at back of drum and reservoir were sealed up?
