Re: Temp limitor
r600a wrote:Hi Spimps
Just replace the micro cut out if its no longer available. the temp is printed on the micro temp.
Bryan
Cheers,
It’s describes as a limite or cut out both on the list and on the part itself, it’s not a one shot toc type device it ‘s really a cut in as the cavity warms up it switches the cooling fan on which sits on top, the one supplied as replacement doesn’t switch the fan on until it gets much hotter than it did originally.
Didn’t see the original as a helpful friend had shorted it out so the fan was running constantly.
Seems to be the jobs when you follow someone else that are a pain!
