Temp & oven select settings on Stoves efa600h worn off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Temp & oven select settings on Stoves efa600h worn off
Viewing 15 posts - 16 through 30 (of 31 total)
  • #211909
    jacpike
    Re: Temp & oven select settings on Stoves efa600h worn o
    Hello
    I have just moved into a new house and have a EFA600H but no instruction manual, can anyone tell me where I can get one from or which setting s to use for what.
    Thanks 🙂
    #211910
    don
    Hi jacpike
    Stoves contact details
    Customer Care – 0871 22 22 502
    Product Info Helpline – 0871 22 22 635
    Spares Direct – 0871 22 22 506
    Or if you want to use the online enquiry http://www.stoves.co.uk/Contact-Us.aspx
    HTH
    Don
    #211911
    jacpike
    Brilliant Thanks 😀
    #211912
    Mandit
    If anoyone could also send me a copy it would be great.
    cant see a thing on my oven or temp dial thing its like a guessing game and one im not very good at!
    is so please pm would be very appreciated.
    thanks
    #211913
    don
    Hi Mandit
    The info you require for ordering instructions is three posts this way ^ 😉
    Don
    #211914
    pinaculo
    If anyone has a picture of the fascia of the Stoves EFa600H I would very much appreciate receiving a copy. My graphics have also disappeared and this guessing game is getting tedious.
    Thanks.
    #211915
    cockney steve
    Although this is a long (and old) thread, I would like to suggest the following.
    Find a local sign/graphics shop who make vinyl signs and lettering.
    they should be able to make facsimilies of the originals (assuming you can get a picture from one of the posters who bought a new fascia.)
    They will also be able to do a clear vinyl overlay to cover the print-area….the finished job would be far more durable than the original stencil and would be a lot cheaper…..the vinyl is cut on a laser-plotter connected to a PC….cheap,quick and effective.
    the vinyl comes in 3-year and 10 -year qualities….but that is for shop and vehicle signs exposed to sun and elements…would last better indoors, I think.
    Suggestion 2….good stationers, -dry transfer lettters/numerals.
    clean the work (meths is good) lay transfer sheet with required item in correct position,..scribble over it with a ball-pen and the item transfers.
    you need to lacquer it after as they just rub off otherwise.
    #211916
    catty
    Please if any one has this picture please sned me a copy I have the same problems with the temp rubbed off and keep burning everything
    #211917
    cockney steve
    Catty…and all who follow with this problem 🙁
    Go to a cookware shop and buy an oven -thermometer….you can then calibrate and mark your dial.(see previous post on Vinyl and Letraset )
    It will probably be more accurate than the original printing, which os probably just an “around-about” sort of average,deduced from a batch of thermostats. 😀
    #211918
    keeper35
    desperate for a photo of the front panel of Stoves Newhome EFa600H as the temperature and oven select settings have worn off. Fed up with takeaways !! e-mail me on david.n.bolton@chase.com Many Thanks.
    #211919
    c_buckers
    i also have the same problem where the details have been rubbed off, could someone please send me a copy of the photo aswell please to my email (cb_the1@hotmail.com) – it would be greatly appreciated!!!!
    #211920
    wit2001large
    Hi.
    Could anyone send me the picture for the front of a stoves EFA600H for the settings??
    Much appreciated if you can: wit2001large@yahoo.co.uk
    cheers!!!
    #211921
    rattyy
    i cant reply to all the emails cos i havent got time -but have taken the time to take pics , (and actually join this site
    http://i339.photobucket.com/albums/n467 … 1Large.jpg
    http://i339.photobucket.com/albums/n467 … 2Large.jpg
    hope this helps –have also put a post in the main forum under cooking appliances with same links
    Hope this helps
    Rich
    #211922
    mcaryf
    Here are the photos again but you need to know if this is the right model of the EFa600h – mine is an 058585102
    http://homepage.ntlworld.com/adam.fox57 … a600h1.JPG
    http://homepage.ntlworld.com/adam.fox57 … a600h2.JPG
    I also obtained the manual but that was hard copy and only a few pounds.
    Regards
    Mike
    #211923
    carrieh77
    Could someone please put the photos back online or send them to me?!
    I’m having the exact same problem having moved into a house with one of these cookers.
    Many thanks
    (and with fingers crossed)
