Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Temp & oven select settings on Stoves efa600h worn off
- This topic has 30 replies, 24 voices, and was last updated 18 years, 11 months ago by
clarison.
April 26, 2007 at 5:38 pm #26920
clarison
ParticipantI have just moved into a new home and the temperature settings and oven select settings on the stainless steel front of the oven (a Stoves Newhome EFa600H Model no. 058585102) have worn off.
This is probably down to over-zealous cleaning. Has anyone any suggestions before I run it past the manufacturer? 😕 Help please!
August 13, 2007 at 9:08 pm #211895clarison
ParticipantRe: Temp & oven select settings on Stoves efa600h worn o
🙁 Come on! No replies… hasn’t anyone got any suggestions?
Manufactuer offered to sell me a whole new fascia panel for £45 plus VAT but I only need a diagram or something of the settings to keep me going. Haven’t had to use much as in middle of renovations, but could really do with some inexpensive help on this. ❗August 13, 2007 at 9:29 pm #211896kwatt
KeymasterRe: Temp & oven select settings on Stoves efa600h worn o
Hi Clarison,
I’m surprised no-one answered this, but never mind…
Basically there’s no way to get the graphics back on there without replacing the panel and, I’d suggest a good non-abrasive cleaner be used in future as well as this is a problem. Due to this being an often heard complain I wrote this article a while ago and I keep testing new stuff, the best so far is by far the Helios/Chromol solution. But, even at that, you can’t get too enthusiastic or you will remove the stencils, even with Helios. However, used with care they are excellent adn I do apologise if that sounds like an advert but you’d be amazed at the number of people that use the wrong cleaners on stainless steel and cause irreparable damage to the steel or stencils. 🙁
The only other thing to can do is use the instruction manual, which if you haven’t got one you should be able to get from Stoves and simply “best guess” it really. There’s not a lot more help we can offer I’m afraid.
HTH
August 15, 2007 at 10:30 am #211897clarison
Thanks a lot for the help… I guess I’m stuck replacing the panel then as the instruction manual (that I have been able to get from Stoves) doesn’t have one single diagram of the front panel… just individual diagrams next to each function and an explanation of what it is etc. Besides this the temperature settings are missing too.
I’ll take a look at the article & thanks a lot for the advice anyway!
October 29, 2007 at 12:51 pm #211898MichelleC
Hi, I have just moved into a house and have got the exact same model oven and the same thing has happened – do you have a picture of the dials for the temperature etc. or did you have to buy a new front? Please help, I haven’t managed to cook anything without burning it in the last week!!
October 29, 2007 at 12:57 pm #211899clarison
Hi Michelle,
I ended up buying a new part, but before I fitted it I took a photo (just in case 😆 ) – if you’d like a copy of the jpeg send me your e-mail address and I’ll forward it to you. It should get you out of trouble for now.
Look foward to hearing from you and hope I can help.
October 29, 2007 at 10:25 pm #211900wsts
ParticipantBe very very careful cleaning the facia on these cookers the graphics seem to come off very easily.
November 6, 2007 at 12:09 pm #211901mdeno2807
ParticipantHi Clarison, could you possibly send through a picture for me? I have sent a personal message with my email contact details.
Many thanks.
November 13, 2007 at 7:47 pm #211902wannacook
oh yes.
please clarison, if you have a picture of the front panel, that would be a big help.
just moved into a new place – and there’s the oven, and I have no clue which position is for which mode… Pity as it seems to be quite a good oven.
found a product-pic but obviously you cannot really tell from the low-res
thanks!
November 20, 2007 at 4:51 pm #211903gemma44
can you please send me a pic too. i have sent a pm with my email details. thanks
gemmaNovember 26, 2007 at 5:04 pm #211904mdeno2807
I contacted Stoves customer service and they sent me the Handbook, but unfortunately that doesn’t help that much. I just can’t figure out how to use the grill 🙁 Am I supposed to be turning the temperature dial right past 220 degrees? Are there grill heats if you go right the way round?
November 30, 2007 at 12:52 pm #211905Philipus
My friends had the same problem!!! Have pm’ed about getting a copy of that photo.
– Philip
January 9, 2008 at 8:06 pm #211906Littlemiss1978
Hiya new to the site but found your post while looking for pics of my oven front as all the settings have rubbed off too – its also a Stoves EFa600h – does anyone have a pic they can email me as Im stuck lol
This must be a very bad desgn fault on there part – also does anyone know where I can get a Fascia at a later date? Would I be able to fit it myself?
ThanksFebruary 28, 2008 at 4:40 pm #211907Allo_al
Does anybody have a picture of the facia that I could have?
March 14, 2008 at 10:34 am #211908bravosystems
Same problem.Moved into my new home and the face plate is nearly fully blank, wish i noticed it before i said yes to the house.
Can anyone send me a photo of there face plate showing me the temps and settings?
Finding it hard to get any help.
Thank you for your time,
Leanne
