Tesco, every little helps!
Home Forums General Trade Forum Tesco, every little helps!
  • #23696
    effzedarr
    Thought you might like to see what some companies charge
    http://direct.tesco.com/help/deliveryinformation.aspx
    Happy New Year, Chris..
    #199037
    maltheviking
    Re: Tesco, every little helps!
    £70 to install a Range Cooker aint’ bad is it?
    I got called to install one just before Chrisy. The guy had bought it from “?” and they would not install it! and neither did I. When I worked out the diversified allowance for amperage his cable from the consumer unit wasn’t heavy enough 😳
    You got to get this re-wired from the consumer unit I informed him, and as I am not Part P registered (although qualified) you will have to get a electrician who is. Mind you it would be interesting to know how Tesco’s installer would have handled it, I don’t think £70 would cover the final bill :rolls:
    I had a cup of coffee with the guy and did not charge him, Merry Christmas
    #199038
    gegsy
    maltheviking wrote: Mind you it would be interesting to know how Tesco’s installer would have handled it, I don’t think £70 would cover the final bill :rolls:
    I would imagine that the £70 would be to install to original wiring etc. Hopefully they have that clause in there or it could prove to be an expensive lesson for them 🙂
    Gas Cooker:
    Tesco wrote:The qualified installer can disconnect your old appliance and connect the new one to a suitable existing gas point providing the point conforms to current CORGI regulations.
    Electric Cooker:
    Tesco wrote:The qualified installer can disconnect your old cooker and connect the new one to a suitable existing supply.
    So they will only install to an existing supply.
    philfish
    Have they got there own engineers/fitteres then? :rolls:
    #199041
    Not if they’ve any sense Phil, it will be sub’d out I should imagine.
