Home › Forums › Public Support Forums › General Enquiries And Questions › Thanks to the bank
- This topic has 3 replies, 4 voices, and was last updated 11 years ago by
kingsley990.
March 21, 2015 at 1:11 pm #84466
kingsley990
ParticipantReceived my new oven door glass received on time and packaged well product looked fine easy fit no problems unfortunately 7 weeks later the glass shattered.
After many emails to admin requesting help and replacement as we stated that the glass should have lasted longer than 7 weeks their response wasThe outer door was faulty
It just happens
Glass doesn’t carry a warranty
And finally being totally ignored 🙁 …………Received poor customer service from yourselves we were successful with our bank using the chargeback scheme and getting a total refund. 😀March 21, 2015 at 6:06 pm #425704SAMURI
ParticipantRe: Thanks to the bank
There are lots of reasons the oven glass can shatter. The glass being faulty is not one of them.
It can be down to a faulty door or misuse.
Do you keep a towel over the oven handle ?.
Did the glass break when you opened the door or did it just shatter with no one nearby.
In the help section is a list of possible reasons a door glass can break.
Bob
March 21, 2015 at 8:00 pm #425705kwatt
KeymasterRe: Thanks to the bank
That article is here:
http://www.ukwhitegoods.co.uk/help/fix- … ement.html
Ovens, cookers and so on use tempered glass, one good knock or a scratch on the glass is enough for it to lose tension and shatter, even from something as seemingly “normal” as sitting a casserole dish or something on it. Slamming the door and even not fitting it back in correctly can all be possible causes.
A recent Watchdog program noted that even “aggressive cleaning” as they put it, would cause a glass to fail.
If there had been a defect from new it would have failed, probably on first use but had it been faulty, it’d probably have arrived in a million pieces.
I would say though that, if you don’t work out what caused it then it’s all too likely to happen again.
March 22, 2015 at 4:34 pm #425706lee8
It will always be someone else’s fault. The change in 2000 didn’t cause computer chaos, it changed people’s perspective from “shit happens” to “it should not happen”.
