THAT WILL BE THE DAEWOO
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts THAT WILL BE THE DAEWOO
  • #6546
    johnmac11
    Help”’
    Where do I get parts for Daewoo fridge freezers from?
    thanks
    John
    #118281
    Dave_Conway
    Re: THAT WILL BE THE DAEWOO
    Connect John, or CPC do some I believe.
    What are you after ?
    #118282
    johnmac11
    Thanks Dave,
    Looked on connect and could not see any Daewoo parts. I need a fridge stat for model ERF340M
    Will phone cpc in the morining if all else fails
    John
    #118283
    Dave_Conway
    Hang fire, I may have the one you want.
    I’ll check the one I have will fit your model and get back to you.
    I don’t suppose you’ve seen the stat have you ? This one has BUZ60 on it and is an air temp capillary type.
    #118284
    johnmac11
    Hi Dave,
    I have not seen the stat but it is an air temp stat
    f you have one I will take it.
    thanks
    John
    #118285
    Dave_Conway
    The one I have is not the right one John 🙁
    According to Connect, the one you need is DAE3018300300 which they have in stock.
    HTH
    #118286
    johnmac11
    Thanks Dave,
    How did you find this part on connections?
    When I go into mediator it does not show me Daewoo as a manufacturer they sell parts for.
    John
    #118287
    johnmac11 wrote:How did you find this part on connections?
    Yep!
    Puzzles me too John??? If I type in ‘Daewoo thermostats ‘ it comes back with a few but not what Dave has come up with???
    Dave_Conway
    I didn’t find it, they did.
    Ah, I know, you are both using the online version, whereas I am using the DVD 😉
    In the DVD (local) version, there is a menu on the left, one of them is “Truelink”, in there it has a few very handy features, one of them is “Part number enquiry” where you can send queries to Connect’s part search team online, they then reply with the answer (not always correctly mind you ;))
    You also have to remember the way Connections works with manufacturers names by shortening them, in this case try typing “thermostatdae” and see what happens.
