Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Thermal cut out – Leisure 100 Range Cooker
- This topic has 7 replies, 2 voices, and was last updated 8 years, 9 months ago by
SeanJ_67.
June 28, 2017 at 1:11 pm #91549
SeanJ_67
ParticipantGood afternoon all,
I wonder if someone can point me in the right direction please. I have an electric Zenith Leisure 100 Range Cooker ZE10CRA.
The clock and fan overn have failed – yet the second oven & hob work fine. I believe it may be the thermal cut out? The problem I have is that although I can buy the part, I can’t find it anywhere on the oven! I’m looking for a button cut out ( like on a tumble dryer). I’ve lifted all the insulation away and I can’t find one. Does anyone know where it’s located please? I’ve seen pictures showing it as on the side wall, but it’s not there. Could it be I have a different type? There is a thick brown wire with some red sleeving in the middle – could that be some kine of couple?
Many thanks
Sean
June 28, 2017 at 1:21 pm #448529kwatt
KeymasterRe: Thermal cut out – Leisure 100 Range Cooker
It should look like this and I think towards the rear:
http://shop.ukwhitegoods.co.uk/21011054 … thermostat
But shown as item 477 on the blowout attached.
June 28, 2017 at 2:22 pm #448530SeanJ_67
ParticipantRe: Thermal cut out – Leisure 100 Range Cooker
Thanks, no sign of that at all.
I do have this wore though – one on each oven. Thats all I can see on the chassis.[
June 28, 2017 at 2:44 pm #448531kwatt
Yup, the looks like the older one if memory serves as I know they updated those a while back.
June 28, 2017 at 3:05 pm #448532SeanJ_67
Ah, I wonder if that’s why the new ones have spade connectors included? So I can cut and fit the new type…
S
June 28, 2017 at 3:06 pm #448533kwatt
Pretty much, yes. That old type hasn’t been available for a few years now so it needs that new kit putting in.
June 28, 2017 at 3:11 pm #448534SeanJ_67
Great, thanks for your help – I’ll order one now 🙂
S
July 1, 2017 at 10:42 am #448535SeanJ_67
Morning,
Ok, I’ve fitted the new cut out and all is well…except now the “keep warm” plate neon is lit constantly even though the knob is set to off.The plate doesn’t warm up. Now all I’ve done is swap the connections over on the cut out.
It’s no big problem, just a bit odd!
S
