Thermostat advice please
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Thermostat advice please
Viewing 15 posts - 1 through 15 (of 15 total)
  • #75775
    normcatalunya
    Hi..We have an old (2006)small chest freezer Westinghouse # WCFCOV31SWR..looks very similar to the Beko CF392W.
    Thermostat duff..Fast freeze OK …Can I use something like a Ranco model as a replacement.?If so which type please.The freezer is very basic with no defrosting facility.
    appreciate any help..
    Thanks in advance..Norm
    #396093
    Re: Thermostat advice please
    A VS5 should do it..
    http://shop.ukwhitegoods.co.uk/vs5-univ … thermostat
    normcatalunya
    Thanks for that!
    #396095
    normcatalunya
    Now ready to fit a VS5 ..Can you please tell me which pair of connections I need to use please..They are # 4,6 and 3..Thanks..
    #396096
    Is there not a wiring diagram in the box or on the pack?
    normcatalunya
    Nada!
    #396098
    normcatalunya
    well tried pins 6 and 4 ..freezer runs but does not switch off?
    Any suggestions please?
    #396099
    SAMURI
    3 & 4
    Black to number 4
    Bob
    #396100
    normcatalunya
    Thanks for that Bob..Tried this..freezer did not run .It had been running constantly for a while so was really cold..but after reconnecting as per your post ..no running until things started to get soft inside….warming up thermo -couple by removing from freezer immediately operated thermostat?Will try to measure some temps..Norm
    #396101
    normcatalunya wrote:warming up thermo -couple by removing from freezer immediately operated thermostat?
    I’m thinking the stat wiring is arse about face? On when off, off when on?
    #396102
    boselecta
    Hi Norm,
    You have broken rule number 8:
    fridge-freezer-forum/professional-advice-the-public-forums-t4360.html
    Obviously before removing any wiring you both made a note on paper and took a photo of the original wiring positions?.
    A classic example of why it pays to get a professional in.
    #396103
    normcatalunya
    Accept that ..but the existing thermostat bares no resemblance connection wise to the original .
    #396104
    normcatalunya
    Just for the record this is the original.. just 2 connections,so thought I could not go wrong 🙁 Is it still possible to buy?Thanks..Norm 😀
    #396105
    normcatalunya
    freezer plate..
    #396106
    SAMURI
    3 & 4 should work ok with the new stat.
    It may have been too cold after running continues
    Have you tried it since to see if it works.
    The stat shown should be available from the whitegoods shop
    Bob
