Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Thermostat burnt out :( need a replacement pls
- This topic has 9 replies, 4 voices, and was last updated 10 years, 9 months ago by
gavlaruk.
June 23, 2015 at 11:24 am #85335
gavlaruk
ParticipantHi, hope you can help, my oven gave a slight burning smell and then failed to heat at all (just the fan etc worked) – i found this thermostat with some burns on it and wondering where i can find a replacement if possible?
The numbers on it are:
??61P ?6 (3) / 250 t175Few photos below to help, many thanks 🙂
Thermostat close up
https://dl.dropboxusercontent.com/u/110 … 120057.JPGIn oven
https://dl.dropboxusercontent.com/u/110 … 201245.jpgRear of oven
https://dl.dropboxusercontent.com/u/110 … 075556.jpgJune 23, 2015 at 1:09 pm #428364kwatt
KeymasterRe: Thermostat burnt out 🙁 need a replacement pls
What oven is it… make and model?
June 23, 2015 at 1:25 pm #428365gavlaruk
ParticipantRe: Thermostat burnt out 🙁 need a replacement pls
I’m not sure on the make and model, no stickers etc.. heres a photo of the front if helps lol, bit of a stab in the dark i know, https://dl.dropboxusercontent.com/u/110 … 075625.jpg
June 23, 2015 at 1:29 pm #428366SAMURI
If the fan is working then the stat is working. You need to check if the Cut out stat in the picture has continuity but normally this cuts out the fan as well if it has failed.
It is more likely to be the fan oven element faulty.
Bob
June 23, 2015 at 2:12 pm #428367gavlaruk
Ive checked the oven heating element and there is continuity… so looked round the back and found that part a bit charred…
June 26, 2015 at 12:29 pm #428368gavlaruk
Guess i’l need to buy a new cooker then? cant seem to find the correct thermostat.
June 26, 2015 at 12:42 pm #428369gavlaruk
This one looks the same? http://shop.ukwhitegoods.co.uk/c0008159 … thermostat
June 26, 2015 at 12:52 pm #428370admin
The cut out is there to stop the oven cavity from overheating, these range from 75oc nc to 160oc nc.
Using one that is set at a lower temp will use the appliance to cut out early and shut the appliance down.
Is there any numbers or labels anywhere on the oven outer case or below the oven door seal ?
Bryan
June 26, 2015 at 1:27 pm #428371gavlaruk
I see ok, best get the right one then 😮 i’l check over the weekend.. thanks for your help 🙂
June 29, 2015 at 7:26 am #428372gavlaruk
Hi… I found the sticker, the details are
Integra AKL848 IX 2.3kw
8541 848 15000
14 0146 005469Many thanks
