I’m trying to source a thermostat for the smaller right hand oven of our Smeg Opera A2-5 cooker.
For some reason the main oven thermostat is readily available around £20, the one for the smaller oven is hard to find and listed around £60. What are the chances that the main oven one would work in the small oven?
Small oven part number
818731208
Large oven part number
818731179
The main oven thermostat was 818731138 that was changed to 818731179 but if your cooker was made prior to 26/10/2003 you cannot fit the later thermostat as an extension rod is needed that is obsolete and there is no solution I’m afraid.
