Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Thermostat for Zanussi Fridge/Freezer
- This topic has 10 replies, 3 voices, and was last updated 21 years, 7 months ago by
admin.
September 6, 2004 at 10:00 am #6192
KeymasterI have just taken delivery of a replacement thermostat (Part No: 5021 59 20-00/5) for my aged Zanussi Fridge Freezer.
However the numbers on the contacts on the new thermostat are different from the old!!
Old terminals are marked, 1, 2 and 3 (1 = Black lead, 2 = Brown/White lead and 3 = White lead)
On the replacment thermostat the terminals are marked, 3, 2/6, 4
Any ideas/help would be appreciated.
MIke
September 6, 2004 at 10:12 am #116141Dave_Conway
ParticipantRe: Thermostat for Zanussi Fridge/Freezer
It depends who made the thermostat.
It should be either a Ranco or Danfoss, this should be on the thermostat itself.
If you can let me know that, I can tell which terminal does what but I won’t be able to tell you which wire goes where as the colours of the leads are irrelevent to a certain axtent.
You would need to find out which one is the main power input, which one goes the the motor (compressor) and which goes to the light switch.
September 6, 2004 at 10:26 am #116142admin
KeymasterRe: Thermostat for Zanussi Fridge/Freezer
Wow, that was quick!!
Thanks for your (very) speedy response Dave.
The thermostat is a Ranco.
Many thanks
Mike
September 6, 2004 at 10:35 am #116143Dave_Conway
OK, as it’s a Ranco:
6 = Main power in
4 = Compressor
3 = Auxillary switch (light or anything else left over)That should do it 😀
September 6, 2004 at 10:56 am #116144admin
Latest info on leads, as follows:
Main power/input is Black – which is also linked to the light switch
Brown lead goes to compressor – but is also linked to a white lead.
There is another white lead on another terminal.The two white leads appear to go from the thermostat to an aluminium element (not too sure if heating or cooling!) which dips down into the fridge compartment and into the drip channel for defrosted water.
Hope this helps
Mike
September 6, 2004 at 11:51 am #116145Dave_Conway
Yeah, the two white leads are the defrost heater, put the spare one on terminal 3.
September 6, 2004 at 3:14 pm #116146admin
Thanks for this and all working as before!!
However…..the new thermostat was recommended to solve my original problem, which was (and still is)..
Freezer (upper) compartment chills to minus 37 deg celcius and Refrigerator (lower) compartment is not chilling at all!!
Mike
September 6, 2004 at 3:28 pm #116147kwatt
KeymasterHi Mike,
You’re on the wrong track with a thermostat for that fault I think. 🙁
It’s far more liable to be a weak compressor, short of gas or a partial choke although there are other problems which could replicate the symptoms. 😕
Do you know the model number and age of the machine, the model number is most important in helping.
September 6, 2004 at 3:49 pm #116148admin
Thanks for the info. I was just working on a recommendation by changing the thermostat. Obviously will ignore him in future!!
The fridge is a Zanussi Fridge/Freezer Model E280/2T. Old – but ideal for keeping the booze in at this time of year! Could say the same about me!
Mike
September 6, 2004 at 5:14 pm #116149Dave_Conway
Yeah, it is an old model.
To be honest, I would cut your losses and replace it as it will almost certainly be one of the faults Ken mentioned, all of them expensive or unrepairable.
September 7, 2004 at 7:12 am #116150admin
Thanks for that. I have already replaced it!
But I am reluctant to throw anything away which looks so good 😆 and may, with a little bit of coaxing, work again, even if it is for garage use.
Thanks for all of your help and advice.
Mike
