Hello, any help appreciated on how to get at the thermostat on a Whirlpool ARC1731/1 larder fridge. I suspect I need to remove the door, but preferably need some confirmation. The thermostat is now set on max and the fridge is just about keeping cool. Used to be set on 3 and was fine so suspect that thermostat needs changing. Nothing in the manual that gives any indication on how to change the thermostat.
could be the termostat does the fridge cut off and on ? if it doesnt . more than likely compressor. or gas low ,, had a few whirpool states not regulating temp well.. .,
