Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Thermostat Phial
- This topic has 14 replies, 3 voices, and was last updated 12 years, 4 months ago by
NoviceDIY.
December 12, 2013 at 3:00 pm #78582
NoviceDIY
ParticipantHi All, would appreciate some help please, I have fitted a new thermostat in my Tricity Bendix Fridge/Frizer. Does anyone know how I fit the phial? I can see the old one goes into the body of the unit but don’t know where and what I attacht the new one to.
Thanks in advance for any help, I won’t let this beat me! 😆
December 12, 2013 at 3:07 pm #406150kwatt
KeymasterRe: Thermostat Phial
You didn’t detach the phial from the thermostat did you?
December 12, 2013 at 4:27 pm #406151NoviceDIY
ParticipantRe: Thermostat Phial
No, I connected the new one, connection by connector, when it came to the “wire” i gave it a little pull but as it didn’t feel as though it was free – felt attached to something, I thought I’d better ask about it. Would I be able to disconnect the old one and connect to the new thermostat???
December 12, 2013 at 4:34 pm #406152kwatt
No, you can’t. If you do the thermostat is trashed.
Same if you bend it too much and kink it or put a hole in it.
You just need to follow the old one and position the replacement one as it is as best you can.
December 12, 2013 at 4:44 pm #406153NoviceDIY
Hi k
thanks for this, advice heeded! I’m getting the feeling this is not something I can get wrong – even by a little bit.
So if I poke the phial down the whole do you know where it comes out to be attached? also if I do this can I leave the old one in place rather than pulling it through the body of the unit? I knnda think they maybe cable ties holding it to other wires.
Thanks K, appreciate the advice, Novice DIY x
December 12, 2013 at 4:47 pm #406154kwatt
You usually have to strip away the housing but, that’s very model dependent.
December 12, 2013 at 4:49 pm #406155Martin
NoviceDIY wrote: Would I be able to disconnect the old one and connect to the new thermostat???
FYI the metal ‘phial’ is a sealed tube filled with a liquid substance that expands and contracts as cold (or heat) is applied. Operating bellows within the thermostat body that in turn operates the on/off switch. So if the phial is punctured then the liquid escapes and the device rendered useless as a result.
December 12, 2013 at 4:55 pm #406156NoviceDIY
Oh dear, I think then that I will have to give up at this point, I will have a look tonight and try and see if I can get to the back of the unit, I can see the “grill” thing at the back and if I can get this off I should have a better idea whether I can remove the backing… pardon my ignorance to what it’s called, this is my first and I think probably my last attempt at repairing white goods! thank you again mate.
December 12, 2013 at 4:58 pm #406157kwatt
That’s the condenser, it’s filled with refrigerant gas so the same rules apply. 😉
Bend it or snap a pipe and it’s night, night Sooty for the unit.
December 12, 2013 at 5:09 pm #406158NoviceDIY
O lordy! how do I get into then?? any ideas please…apart from a sledgehammer ! what about removing the metal cooling plate?
December 12, 2013 at 5:17 pm #406159kwatt
Same rules apply, that’s full of refrigerant as well. 😉
Both can be moved but, you have to be careful.
December 12, 2013 at 5:34 pm #406160Martin
How’s about you give us the full model number (PNc no) of this TricityBendix?
December 12, 2013 at 5:59 pm #406161NoviceDIY
Ok, no pressure here 🙂 but what would you do? I’m already resigned to the fact that I’m not going to be able to fix this problem, to be honest the unit is at least 20 years old and owes me no favours, but the stubborn mule in me won’t let it lie :)))
December 12, 2013 at 6:27 pm #406162Martin
NoviceDIY wrote:Ok, no pressure here 🙂 but what would you do?
Ask you (twice) for the model number. :rolls:
December 13, 2013 at 8:06 am #406163NoviceDIY
Morning Chaps, well guess what? I managed to fix it, 4 long hours but I DID IT! sorry Martin I had gone when you posted, my posts were out of sync yesterday, I wasn’t ignoring you hun.
Thank you once again k and Martin for your advice in was invaluable.
so I’m one happy chick today, albeit that I rushed out last week and bought a new fridge but hey! more room to cool the bubbles.
I will defo use this site again, please take pity on me again.
Happy Christmas to you and many many thanks again, X
