Thermostat Repeated Rapid Failure
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Thermostat Repeated Rapid Failure
  • #77905
    kamawell
    I’ve got an Indesit G74C that’s stopped heating. I’ve replaced the thermostats twice in the past and did it for a third time the other day. The new one failed almost straight away. I cleared every last bit of fluff I can find anywhere in the machine but another has failed after a couple of hours this morning. I have to admit buying cheap ones from another place and only replacing the one that had gone (I see that the guidance here is to replace them in pairs.)
    Before I order a proper pair from ukwhitegoods can anyone suggest anything else that could be causing there to fail so quickly?
    Andy
    #403796
    Re: Thermostat Repeated Rapid Failure
    some of the most common reasons for thermostat failure are here:
    http://www.ukwhitegoods.co.uk/help/fix- … lures.html
    In all honesty, 99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time, it’s down to one or more of the reasons there as there’s little else that can possibly cause repeated or even a single failure.
    bazza500
    You must replace them both.
    If the one you are not replacing is the faulty one it will keep causing the other one to blow.
    #403798
    Andy jones
    Make sure you don’t keep opening the door whilst drying to check
    I get loads of people that don’t let it go through its cooling period which is vital
