This amount of vibration on new Bosch 6 washing machine
Home Forums Public Support Forums General Enquiries And Questions This amount of vibration on new Bosch 6 washing machine
  • #103537
    bc463927
    Had this posh series 6 washing machine installed a week ago. It is on a concrete floor. I’m surprised about the amount of vibration on the spin cycle (previous experience was with a Miele W1, which barely moved). I was looking to get views before getting someone to look at it
    https://share.icloud.com/photos/0e25Th0uE-BJWv4IIdVnj1Tmw
    #493517
    That looks okay but, it’s not a Miele.
    bc463927
    kwatt wrote:That looks okay but, it’s not a Miele.
    Thank you! I must have been spoilt!
    #493519
    miele’s are a lot heavier. never been able to deliver Miele machines on my own
    you have only got to drive a heavier car down a bumpy street and then drive a lighter one to realise the reason why the Bosch moves more
    bc463927
    After a few more uses we have found our washing machine is walking! About 15cm. It was level with this tumble dryer:
    #493521
    you can get the odd load that does ont balance correctly but it should not do it every time
    is the floor springy there or is it concrete
    bc463927
    electrofix wrote:you can get the odd load that does ont balance correctly but it should not do it every time
    It’s concrete (not perfectly smooth, mind)
    #493523
    does not matter how smooth as long as the legs are adjusted
    the main thing is its concrete as wooden floors can add a spring to the problem
    Is it possible that the feet are the issue as in, they’re slipping on the smooth surface? The Miele ones could have been a different material that gripped better.
