Too cold Fridgemaster fridge MTRL130
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Too cold Fridgemaster fridge MTRL130
  • #13796
    macclad
    fridge is constantly too cold even when at lowest setting possible. can anyone tell me how to fix and cost? Is it just thermostat?
    thanks
    macclad
    #156644
    gegsy
    Re: Too cold Fridgemaster fridge MTRL130
    Do you get frozen littles bobbles starting at rear top back evenly spreading 3/4 way down to just above drain hole??
    How old is appliance??
    Kirk
    It could be a simple T Stat fault but first, I would check that there is a big build up of ice on the back wall all over the upper part, if it is only half down and lower half is clear it will be the stat. If it comes down to the defrost hole it could have a more seirous problem.
    Kirk
    #156646
    macclad
    cheers
    i get bobbles on the back middle third but also ice builds up over few weeks covering bottom third but not quite over defrost hole.
    #156647
    Kirk
    This model had a problem with the defrost cycle not defrosting all the ice, so slowly building up above the drain hole and eventually covering it, usually the water leaks onto the bottom of the fridge then the floor if this hasn’t happened it is probably the stat.
    Kirk
    #156648
    Voodoophone
    gegsy wrote:Do you get frozen littles bobbles starting at rear top back evenly spreading 3/4 way down to just above drain hole??
    I have a brand new fridgemaster that is getting these ‘bobbles’
    What does it signify?
    #156649
    The small dropplets of water frozen on the back wall of the fridge is normal.
    Bryan
    #156650
    helo_75
    if it was myself, id just be glad it was keeping my food cold
    larder fridges are always 2-3 degrees warmer as a rule
    you still havent asked who manufactures these? and then you’ll have your answer
    #156651
    cockney steve
    OK, I’ll bite 😆 Haier or Indes*it ?
    #156652
    helo_75
    lol, not daft are you
