Top Oven
  • #93713
    puppy
    Hi Have a Hotpoint Creda S420EKH, 07341140000 and the top oven is not heating fully. The element has been changed and it seemed to heat but I got a thermometer and it is only heating to 130 degrees. Thermostat light stays on all the time. Thanks
    #455326
    Re: Top Oven
    most top ovens have 2 elements. one is the grill element but there is another one under the floor.
    which one did you change ?
    puppy
    Re: Top Oven
    The one at the top with three small tubes
    #455328
    Re: Top Oven
    in that case there is another element under the floor. If that has failed it wont get to temp
    you have to take the back off the cooker to access it
    puppy
    Re: Top Oven
    Oh, ok many thanks for that
    #455330
    Re: Top Oven
    if its faulty part you need is
    gen part
    https://shop.ukwhitegoods.co.uk/c002338 … se-element
    pattern part to fit
    https://shop.ukwhitegoods.co.uk/14cr10- … se-element
