i have a diplomat adp4520 double oven ,
the bottom oven is fine but both the top oven and grill have stopped working ,even though the fan still comes on
What is the most likely cause and isit a relatively easy fix ?
hard to say really 1 possibility is that the grill has not worked in a while and now your top oven has gone you have decided to use the grill or vise versa, and now your putting 2 and 2 together and thinking that both have gone at the same time best thing to do would be to call an engineer in bit hard to make a diagnosis over the internet with something like that
Spares are available but be careful when fitting as probaly you need to take the whole oven out and remove the back to fit.
As always play safe and turn electrioc off to the oven at the cooker switch and mains if doing. Most competent electricians should be able to fit one if you purchas the part required.
