top oven on AEG D4100M double oven overheats
Home Forums Public Support Forums Help And Support Cooker And Oven Forum top oven on AEG D4100M double oven overheats
  • #58557
    LumPT
    Having recently taken over more kitchen responsibilities at home (it’s a long story…) I’m determined to fix our oven. It’s about 7 years old and the top oven just keeps on heating up beyond the temperature it is set at.
    I guess it is the thermostat which needs to be replaced but thought I’d bounce this off you good folks before doing anything rash…
    The oven is an AEG D4100M double oven and its product number is 944171156
    Thanks in anticipation.
    #334916
    tipshornal
    Re: top oven on AEG D4100M double oven overheats
    I have a similar problem with an AEG single oven (Competence B8871-4). did you get a satisfactory response to your question?
    thanks.
    #334917
    LumPT
    Hi, Sadly noone offered an answer. I have not made any progress myself either.
    Good luck.
    #334918
    LumPT wrote:I have not made any progress myself either.
    From what you say it must only be a thermostat issue with the top oven. Therefore a replacement (Part No: 3111655019) would be the obvious solution I would think?
    I’m assuming the top oven thermostat control is the one on the far right of the control panel in this case? If so that’s the part you need and available by emailing spares@ukwhitegoods.co.uk
    HTH? 😀
    #334919
    LumPT
    Martin, Excellent, thanks for your help
