toshiba microwave bulb
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts toshiba microwave bulb
  • #87068
    cab
    Hi all the inlaws have a very old Toshiba microwave and the bulb has gone, major catastrophe for the elderly, Its model is ER-582ET the bulb is a screw in type but is bigger than the current type can anyone help please?
    thanks
    Cliff
    #433871
    don
    Re: toshiba microwave bulb
    Hi Cliff
    Can’t find anything on this now, is the lamp golf ball shape and is the thread about half inch across or an inch across?
    Don
    #433872
    cab
    yep golf ball shaped outer diameter of thread is about 16mm (.65″) using a metric Vernier! slightly bigger than half inch
    #433873
    don
    Sounds like you need a SES threaded golfball they come in 25w, 40w or 60w.
    Bosch use 40w SES golf rated at 300 degrees which is probably a better bet. in a microwave
    Don
    Moved to Trade spares 😉
    #433874
    cab
    do you know a part number just looked on ebay the standard ses threaded bulb is an E14 can only find these which will be too small
    #433875
    don
    In that case it is probably an E17 thread size which fits with your 16.5mm measurement. Could it be one of then ? Hope it is 🙂 I have to say I have not come across that size before!!
    Don
    #433876
    cab
    it looks like the E17 very flat bottom, thanks for the help,:)
