Have been to one of these and the fault code reads as 2 flashes and two beeps(not draining) and TDS says it is faulty board or element. Element checks out ok as does the board by EMW.
Any clues most welcome.
Rob
Thanks Chris.
Back to square one.
Dunno what to do about this now as everything seems to check out. No blockage,p/sw ok and so is pcb.Probably give up now.
Rob
Had one with pump reading 4 ohms after pen in filter. disconnected pump got drum to turn on drain. connected new pump two flashes again. assumed module.
