Tricity AW1200
  • #26267
    abbeyelectrics
    Does anyone know the PE Leak a Tricity AW1200 should kick out? I can’t get hold of Tricity to find out.
    Thanks in advance
    Richard
    #209430
    Dave_Conway
    Re: Tricity AW1200
    abbeyelectrics wrote:PE Leak
    The what ? :con:
    Re: Tricity AW1200
    Something to do with earth leakage?
    :p45:
    #209432
    abbeyelectrics
    Re: Tricity AW1200
    On our PAT tester when doing a load test it does:
    Load – A
    Load – KVA
    PE Leak – MA
    It’s failing the PE Leak saying it’s reached it’s limit although every other test it passes including Earth Bond Test.
    #209433
    abbots
    Re: Tricity AW1200
    sounds a bit like a phase to earth leakage test which some pat testers do instead of a full insulation resistance test at 500v DC.
    if it is i think of the top of my head the max figure for a earth leakage test is 3.5mA for a class one appliance.
    what is the insulation test results?
    john
    #209434
    abbeyelectrics
    Re: Tricity AW1200
    I’ve just taken some more readings and they are as Follows:
    Insulation Test – 299m ohms – Pass
    Earth Bond – 0.00 ohms – Pass
    Load/Leak Test – 7.7 a – Fail
    1.7kva – Fail
    2.10 ma – Fail Limit
    I hope someone can shed some light.
    Richard
    #209435
    abbots
    Re: Tricity AW1200
    sounds fine to me.
    the fail tests relate to earth leakage tests.This is a “soft” test applied to appliances not designed for insulation resistance tests at 500 v DC.
    the IEE “code of practise for in-service inspection and testing of electrical appliances ” states that the following tests should be applied to class I appliances.
    (1)preliminary inspection
    (2)earth continuity test
    (3)insulation resistance
    (4)functional checks
    your machine passes (2) and (3) so as long as it passes a visual inspection and a functional test(ie it works) then it passes.
    john
    #209436
    abbeyelectrics
    Re: Tricity AW1200
    Thanks very much for your help, it’s really appreciated.
    Richard
